Hi.
Like the title says, since equipment with switch mode supplies has become common, I have noticed that many of them give me minor electric shocks. I'm wondering if anybody knows why?
I don't really know what sort of info you need, but will try to list all the stuff I think is relevant, so this might be a bit long. I think it is unlikely to be a mains wiring problem, as I have moved house six or seven times since 2000, and it still keeps happening.
I think it must be something to do with the supplies themselves, I guess they are putting a voltage on the parts that are supposed to be grounded, and it must be quite significant, as I can feel it when I would expect to be well insulated from any alternate ground path.
For example, what is making me type this is that my e-cig keeps zapping my lips. It charges while in use from a USB connection to my laptop. The laptop is powered by a Delta branded PSU, which I believe is a competent brand, and as far as I know it is genuine, not a nasty fake. This is just an example though, have had this problem many times before.
The part I really don't understand, even if there is somehow a lot of volts on the supposed earth parts, there is no return path. I'm sat on my bed. At least an inch of fabric between my body and anything conductive. Even if I am conducting to the bed, it is sat on a wooden floor.
I asked this on some other forum ten years ago, and all I got was recommendations to get the mains tested. I hope someone here has something more well informed.
Thanks.
