Hello all!
I've been assigned the task of reviving this circuit board. When I received the board, only a few pieces of the transformer was remaining. I havent had much luck trying to find a similar transformer, and I was wondering you could help me on this.
The footprint of the transformer is shown in the attached picture. The fuses are rated to 10A. The fuses appears connected in series with the primary of the transformer. The secondary is connected to a rectifier with the following ingraving: "F, T350, GBU, 8M", and then a 7818 regulator.
