The well known AM TRF receiver on a 3-pin chip. Datasheet:
http://www.shenzhensum.com/products/datasheet/TA7642.pdfWhile the last stage is nominally a detector it looks (from the equivalent circuit and from the fact that people have made regenerative sets from them) like if the 100n is left off of the output and perhaps the bias is tweaked a little then most of the amplified RF still comes out. If so that would make it rather useful for something I'm working on which needs a fairly wideband input stage centred on 1 MHz. I'm going to order a few and have a play but in the meantime a few questions:
Is there a similar part without the detector (or with the intermediate connection brought out)?
Has anyone here used one for this purpose?
Does anyone have any spice models for the part?
Failing that some suggestions for transistor parameters to try in a model of the equivalent circuit would be appreciated.
Thanks
Richard
