Author Topic: Modular Electronics -- Looking for alpha testers/Early adopters!  (Read 3810 times)
Offline AsaadTopic starter
Hi folks,
I've been working on an exciting modular electronics system for some time. It's quite novel and distinguished from anything you'd see out there, but it's still in a very rough shape.
I'm looking for some brave early adopters / alpha testers (preferably in the US) to provide valuable feedback, contribute their ideas/projects and be the core of a future community. High expertise in hardware / embedded systems is not required. A good experience is enough but what's important is passion and drive. I'll provide all the tools/hardware you need to start tinkering with the system. You will be among the few dozen people trying this and the hardware quantity I have is very limited so it'll be first-come-first-serve (if you're a suitable tester)
Below some teaser pictures! If you're excited about this please PM me introducing yourself and why you're the best tester on planet ;)
« Last Edit: August 20, 2017, 03:53:51 am by Asaad »
Offline Geerant101
Re: Modular Electronics -- Looking for alpha testers/Early adopters!
« Reply #1 on: August 20, 2017, 07:26:54 am »
Nice concept, I really like it. I have been looking at something very similar for a while now. I have found (Google) that solder blobs might not be as good in practise as they appear in theory. I can see you have built many actual prototypes so I would be interested in how the connections go physically.
Sent from my SM-G920I using Tapatalk
« Reply #2 on: August 20, 2017, 08:06:42 am »
Thanks! Soldering is not optimal but it worked really well. It's a compromise between reliability and reconfigurablity.
Soldered edges are more rigid and more reliable. They're smaller, lighter and cheaper than most connectors and wires. So if you have a size/weight-constrained application (e.g., a drone) they do much better job. Of course, if you abuse them, you can pull the traces off but this is the case with any SMD connections. You can still use connectors instead. It does not change the main design concept.
Offline Geerant101
« Reply #3 on: August 20, 2017, 09:49:35 am »
Well that's good to hear I might have to give it a go :) perhaps using vias aswell would minimise the traces peeling back? You are right tho, connectors in general are expensive!
« Reply #4 on: August 21, 2017, 02:40:16 am »
Yep using vias definitely helps if you have same signal on both sides.
Offline Geerant101
« Reply #5 on: August 21, 2017, 02:43:25 am »
Even just for added mechanical strength.
Offline MechEng87
« Reply #6 on: August 21, 2017, 03:39:52 am »
Looks like a great idea. Id definitely be willing to do some testing for the product. What are the different modules that you have made so far? I see some power modules maybe in the third picture, and a whole bunch of micros.  What else have you put on the boards?
« Reply #7 on: August 21, 2017, 05:08:45 am »
MechEng87 please PM some information about yourself and I'll share with you more details about the project if you're interested to give it a try. Currently I have 6 modules ready and about 10 in the work. There's RGB LED, uSD card, DC power supply, batteries, solid state relay, digital serializer, Ethernet, BLE, audio amplifier, USBs (standard, mini, micro) and sensor hub among others. I'm hoping to have some free time to finish about 25 modules by the end of the year. Most development goes to APIs and the embedded operating system.
Offline hendorog
« Reply #8 on: August 21, 2017, 06:37:27 am »
Solar tab wire would be perfect for making those solder blob joins more robust - if I understand what you are doing. It has a solder coating already so would take about 2 seconds to apply. Easy to desolder without solder wick - if you leave a little extra folded up to grab with pliers.
Edit: This stuff:
http://www.ebay.com/itm/36-9-14m-x-2mm-w-solder-solar-cells-TAB-tabbing-WIRE-/180531128629?hash=item2a087e6935:g:TBMAAOSwYmZXIiQM
Offline firehopper
« Reply #9 on: August 21, 2017, 11:17:02 pm »
I have some of that solder tab stuff.. it might make it a little harder to reconfigure the modules though.
« Reply #10 on: August 22, 2017, 01:59:17 am »
The solar tabs are a nice idea although I don't think you need it in most applications. The array (as I call these boards) rigidity and reliability are quite good for typical applications and light loads. For really large arrays (like the big one showed above with 37 modules), it's better to have some structural support and protection. Since I was aiming for an extremely lightweight design in one particular application, I 3d printed lightweight structural flat and spherical frames to provide physical support.
Reconfigurability is key here. I can reliably use the array for months and years and then add or remove modules (or change shape) in 10 minutes with a solder iron. You don't even need to remove the solder completely. Just heat it up and it'll split into two smaller blobs. Heat again and they will merge.
Offline Geerant101
« Reply #11 on: August 22, 2017, 02:10:37 am »
If reconfigurability then solder blobs connecting the modules to each other may not be ideal. Any connector would option would add cost but makes it very easy to reconfigure..
Just another 2c
« Reply #12 on: August 22, 2017, 02:18:03 am »
True, it's not plug and play level but that's not the requirement here. I was looking for something more flexible than a custom made PCB that can never be changed or re-purposed and more reliable and compact than development boards connected with wires, connectors, etc.
Giving said that, nothing prevents you from using special connectors as long as you can find cheap genderless ones. If you use males and females then you'll lose some modularity in the design but it might be OK. All these variables can be optimized for different applications.
Offline Geerant101
« Reply #13 on: August 22, 2017, 02:29:52 am »
"more flexible than a custom made PCB that can never be changed or re-purposed and more reliable and compact than development boards connected with wires, connectors, etc"
I actually missed this.. This is a very good concept, I like it alot and it will be very  powerful. You could have a standard interface between the modules eg. power, I2C ADC etc aswell.
Offline rs20
« Reply #14 on: August 22, 2017, 03:32:17 am »
It's like mini solar roadways! :D
Offline Geerant101
« Reply #15 on: August 22, 2017, 03:49:36 am »
A mini solar roadways which is only for R&D and not trying to be for production..
Offline dnwheeler
« Reply #16 on: August 22, 2017, 04:12:18 pm »
Just adding through-holes to each pad would allow the optional use of a small jumper wire for structural support (but still allow just a solder blob). I'm also wondering if it might be possible to get some sort of "H" shaped connector (just a bare metal spring clip) that the two boards could slide into. I've seen similar clips with a pin on one side, but haven't seen a dual clip design.
Offline trophosphere
« Reply #17 on: August 22, 2017, 06:37:25 pm »
Have you looked into using the RotaConnect connectors to attach the PCBs to one another. They are (for the purposes of your BOM) essentially genderless and can connect to one another at different angles thus allowing you to keep the overall shapes you've made.
The following users thanked this post: cgroen
« Reply #18 on: August 23, 2017, 03:29:11 am »
There are different signals on top and bottom side of each solder joint thus a through-hole solution is not really feasible. Usually if I want to get external access to the array I solder the ultra-cheap 2.54 male header connectors and connect them to jumper wires. They're a bit wider than board thickness (~1.6mm) but with solder they stick there really well.
« Reply #19 on: August 23, 2017, 03:43:48 am »
Actually I haven't heard of those before! The board-to-board ones are really nice. Might be good for some fancy plug-n-play applications. For most practical applications though, it's an overkill. They're almost more expensive than the modules themselves. If you want to replace all solder joints for a hexagon that's 24 x $0.5 (cheapest wholesale price) = $12! You will need also a bit larger modules. The ones I have are really tiny: 30mm side-to-side.
« Reply #20 on: August 26, 2017, 10:40:31 pm »
More weird shapes and configurations!
