Currently resuming a long shelved project, and have thought up and simulated an idea that appear to work, but i figure i may as well run it by here first. as it feels too simple,
I have to output a 5V supply (+-0.5V) of at least 1mA, into the world, the internal supply its fed from is 5V +- 0.02V, and the plug it connects to may be connected between hard + or -32V DC.
(by hard i mean a direct unfused connection to a supply that can supply many amps, and cannot be crowbar'd)
so far i have dreamed up the following, it looses about 0.35V across the schottkey, and 0.1V across the resistor, it's within my specs, limiting current when negative, and the diode blocking when positive, and as a bonus, disabling the output when the 5V internal supply is turned off,
But i cant shake the feeling i have missed something obvious.
