I'm trying to make a pretty basic mosfet regulator but so far I failed miserably.
Have a look at the schematic attached.
My multimeter is between Va and ground, Vdc 600V selected, and when I turn my transformer on, I hear a pretty bad clicking noise (typical noise of a faulty semiconductor or short, you know what I mean) at 100Hz and the DMM is gone.
Same result with a second multimeter.
My multimeters were pretty cheap but have done the work for many years. Its rated CAT II 600V, but I saw the thread on the cheap-ass multimeters shootout...
But c'mon, its at best 450Vdc so I don't understand why it fails like that.
There is probably a problem with a part in the schematic, but I replaced every semiconductors and the wiring after that and the problem stays the same.
Even without the DMM connected I have this bad clicking noise.
Meanwhile, I ordered a descent Fluke 179
, but I hope it will hold this situation...
Have I done something wrong ? I don't understand what the problem is. Any advice would be appreciated !
Thanks !
