No, there is no issue with a MOSFET operating in the linear region. It is perfectly fine.
You are driving the gate with 30 volts. Make sure that the MOSFET you are using will support a VGS=30V
BTW, your notation about M2 says that it operates in Sat. It appears to me that it too operates in the linear region...which is OK!
You may be a little confused about the terminology. At a basic level, a MOSFET is either ON or OFF. When OFF, there are no "regions" per say. When it is ON, it can be in linear or saturation region.
