Hi
I'm new here, a woodworking hobbyist dabbling in adding electronics to some projects.
I have some Qi wireless charging components, and looking for advice on a couple of things. I am mounting the components basically inside a small wooden box, on the underside of the 'lid' of the box.
The PCBA I have looks just like the linked one.
https://www.aliexpress.com/item/DIY-Wireless-Phone-Charger-PCBA-Circuit-Board-Coil-Micro-USB-Port-DC-5V-Qi-Standard-Universal/32838102206.htmlMy questions:
- suggestions for best way to mount the coil/magnet and circuit board? Glue? I have some double sided 3M tape meant to hold photos to walls etc. Have also tried PL glue, but would like something easier to 'undo' for troubleshooting.
- In my design the LED light attached to the board will stay inside the box and I'd like to run a light conducting material from it to the edge of the box exterior. I have experimented with strips of acrylic and thin fiber optics I got from a hobby shop, with mixed results. Specifically, is there a good way to attach or bond the light conducting materials to the LED? Like with wrapping tape around it or a dab of CA glue or something?
- Is it safe to bend the prongs the LED is mounted to, and if so by how much? 90 degrees etc...?
Separate questions on obtaining components:
- I've had the best luck on AliExpress finding the components. Is there somewhere better?
- I've also been looking for USB flash drives with a plain metal sleeve, i.e. no case, but haven't had much luck. Suggestions?
Thanks for reading.
Paul
