Author Topic: My electromagnetic BB gun project, 130 m/s velocity, 20 rpm rate of fire  (Read 10095 times)
Offline rpopeyeTopic starter
  • Country: bg
So, this is my baby - an electromagnetic BB gun (coil gun), that shoots standard size 4.5mm steel BBs with a velocity of up to 130 m/s and a rate of fire of 20 rpm. It's basically as good as an average CO2 BB airgun and, as far as I am aware, is the first practically usable electromagnetic BB gun. I know that the height of the coil gun hype is long past, but I think we are now entering the next stage where the concept may actually become practically usable, at least in the recreational shooting area.
It's basically a standard coil gun design - a series of coils along the barrel are switched on and off in rapid succession creating a running electromagnetic field from the back of the barrel towards the front which attracts and accelerates the steel BB. To achieve these high velocities the coils are powered from a high voltage capacitor bank, which in turn is charged up from a 2.5 Ah 25C 3s LiPo battery by means of a boost DC-DC converter. A single charge of the battery is sufficient for more than 300 shots. The whole thing is controlled by two PIC micro-controllers - one master and one for generating the pulses. The coils are switched by mosfet transistors and the schematics is pretty standard (attached).
Took me about a year to design, 3D print and build, but it was worth it  :)
Check out my demo video where I shatter glass bottles with it.
https://youtu.be/jhtAsYy7dgM
The following users thanked this post: daqq, tautech, lem_ix, jonovid, Wimberleytech, Neomys Sapiens, I wanted a rude username
Offline boatanchorguy
Re: My electromagnetic BB gun project, 130 m/s velocity, 20 rpm rate of fire
« Reply #1 on: January 16, 2018, 01:04:53 pm »
Very cool.. do you have some pictures of the interior showing the coils and other construction?
Offline daqq
  • Country: sk
    • My site
« Reply #2 on: January 16, 2018, 01:58:09 pm »
Nice build!
If you need the field in the coils to decay faster once the MOSFET has been turned of you might want to add a series resistor (or a different dissipative snubber) to the flyback diode.
I know that I gained a bit of lower efficiency in my old (very simple) coilgun because the field in the inductor was still present after the ball passed through it, creating a drag.
  • Country: bg
« Reply #3 on: January 16, 2018, 03:29:19 pm »
thanks daqq, that's a good idea, have to be careful however not to over-voltage the mosfet with the drop on the resistor that will add on top of the remaining voltage in the capacitor
  • Country: bg
« Reply #4 on: January 16, 2018, 03:32:31 pm »
Here is a picture of the interior, the rest of the volume is pretty much filled with capacitors  ;D
The following users thanked this post: jonovid
Offline moonquasar
« Reply #5 on: January 17, 2018, 04:12:29 am »
Very nice build.  Are there sensors to track the bb or is it open loop?
Offline tpowell1830
  • Peacefully retired from industry, active in life
« Reply #6 on: January 17, 2018, 05:19:55 am »
It is difficult to see, but it looks similar to a linear motor. Is that the mode of operation?
PEACE===>T
Offline tautech
« Reply #7 on: January 17, 2018, 06:18:20 am »
What degree of accuracy has been achieved ? Say a 25m group ?
Avid Rabid Hobbyist
  • Country: bg
« Reply #8 on: January 17, 2018, 06:24:56 am »
Yes, it is basically a linear motor
What is visible in the interior picture are the mosfet transistors sitting on top of the coils
It doesn't have sensors to track the BB and indeed works in an open loop configuration
Currently the accuracy is pretty bad (10cm spread at 6m) due to the lack of precision instruments when making the barrel - there is a considerable gap (0.5mm) between the barrel internal diameter and the diameter of the BBs, and also the barrel is most likely not exactly straight
The following users thanked this post: tpowell1830
Offline tautech
« Reply #9 on: January 17, 2018, 06:38:20 am »
Could the barrel be precision bored to the correct size after manufacture ?
What length is the barrel ?
Is it possible the field is not even and effects the path of the BB near exit ?
Could a plain tube extension be added to improve accuracy ?
Avid Rabid Hobbyist
  • Country: bg
« Reply #10 on: January 17, 2018, 08:28:26 am »
The barrel is 50cm long and can be precision manufactured to tightly fit the BB's diameter, I just don't have the tools, so I used an off-the-shelf acrylic glass tube instead. Unfortunately, the required internal diameter wasn't available so I had to go with slightly larger and also acrylic glass is flexible, so exact straightness couldn't be ensured either.
The field is radially uniform, so in theory shouldn't affect the path of the BB.
There is a conical tube extension at the end of the barrel if that's what you meant. Without it the accuracy might have been even worse.
I think the main problem is the large internal diameter and straightness of the barrel - the BB most likely bounces off the walls inside the barrel and when exiting its path deviates from the straight axis.
Offline tpowell1830
« Reply #11 on: January 17, 2018, 03:38:59 pm »
Is there a method to allow air to enter the back of the barrel, behind the BB? If this is not allowed, you could perhaps be pulling a vacuum in the accel chamber, behind the BB, slowing the process. There is a considerable fluid dynamic occurring here.
Also, the precision of the barrel is a consideration, once the fluid dynamic is handled. This is a wonderful device that you have built, but I believe many improvements can make it, not only accurate at a distance, but considerably faster. The speed of sound is one of the factors.
Have you considered going to the 6mm BB? It is unfortunate that we are not close in proximity and I could look at the problem more closely. What a fun project! And you have done a beautiful job of the entire system. I am certain you can overcome these issues.
« Last Edit: January 17, 2018, 03:41:58 pm by tpowell1830 »
PEACE===>T
The following users thanked this post: rpopeye, I wanted a rude username
Offline alexanderbrevig
  • Country: no
  • Musician, developer and EE hobbyist
    • alexanderbrevig.com
« Reply #12 on: January 17, 2018, 03:45:51 pm »
Just wanted to congratulate you on an awesome and fun project! Such a nice build too! :D  :-+
Online langwadt
« Reply #13 on: January 17, 2018, 04:07:42 pm »
when you exceed the D-S voltage on a mosfet it start acting like a zener diode, so the limit os how much power it can handle not voltage. Look for avalanche rated mosfets, they specify how much energy they can handle
if it is within the limits of how much is stored in the inductor you can skip the flyback diode
  • Country: bg
« Reply #14 on: January 17, 2018, 04:57:21 pm »
Yes, there is an opening at the back of the barrel from where air can enter when the BB is being accelerated, otherwise it indeed creates vacuum behind itself which considerably slows it down and also creates a funny sound when exiting the barrel :)
I've already started working on the next version, which should see many improvements, at least I've found a tube with the right diameter, so accuracy should get a boost. I am also expecting the velocity to reach 160m/s, but for now the speed of sound looks like a very far away goal :)
Using 6mm BBs would certainly give it more kinetic energy and at some point in the future I would like to try them, but first I want to make the 4.5mm ones work sufficiently well. I might also try 4.5mm steel pellets though as they would require only software modifications and probably only minor changes to the loading mechanism.
  • Country: bg
« Reply #15 on: January 17, 2018, 05:06:46 pm »
Yes, the mosfets are avalanche rated. I haven't calculated how much energy the coil would dump on the mosfet, but I did an experiment without the flyback diode and sadly the mosfet died. I even had to use fast diodes, it seems the general purpose ones did not switch on fast enough to prevent the avalanche in the mosfet.
Offline dexters_lab
« Reply #16 on: January 17, 2018, 07:17:01 pm »
great project, it's really nice to see a home brew project finished so completely!
what is the voltage/capacitance dumped into each coil?
Offline daqq
  • Country: sk
    • My site
« Reply #17 on: January 17, 2018, 09:49:18 pm »
The maximum voltage produced by an inductor should be the current that was flowing thought it at the time of the disconnection times the resistance in series with the flyback diode (plus the diode voltage). Try simulating it in LTSpice.
  • Country: bg
« Reply #18 on: January 18, 2018, 06:25:31 am »
The capacitor bank is charged up to 95 V, but the mosfets switch off the coils at the right times to achieve maximum velocity, so not all of the capacitance is dumped on the coils. The energy dumped on the first coil is about 7 joules (calculated, I don't have the means to actually measure it), it gets progressively smaller for the other coils as the length of the switched on time decreases with increasing velocity of the projectile. The efficiency of the whole thing is about 2%, pretty bad, but sufficient for this version.
In the next version I am planning to do more simulations and testing to optimize the circuit and hopefully achieve better efficiency.
Speaking of efficiency, does anybody know the main reason for why coil guns are so notoriously inefficient?
I can thing of two - active losses in the coil wire and poor magnetic coupling between the coil and the projectile, but I don't know how strong these effects are.
Apparently DARPA has achieved 22% efficiency in their design of a coilgun mortar according to Wikipedia, but of course the design I suppose is classified and not publicly available.
« Last Edit: January 18, 2018, 06:44:54 am by rpopeye »
Offline Rerouter
« Reply #19 on: January 18, 2018, 10:38:28 am »
The darpa coil guns used many smaller bifilar wound pairs to reduce the inductance between the capacitor bank and the coil, they also likely used many parrellel turns instead of a true coil, to increase the amperage while keeping the voltage lower,
due to insulation gap, they likely would have tried to keep the voltages lower as that way you can get more joules closer to the barrel if you can maximize for joules/cubic meter.
They also would have segmented and closed the magnetic path outside of the barrel to focus the magnetic field lines and prevent influence from adjacent coils, like the iron washers many designs seem to use, I assume they would have gone a step furthur and made a 2 part shell to encase the outside of each coil.
Square magnet wire is also likely on the cards, gets a bit lower resistance for the same number of turns however this costs much more for hobbies.
The other trick they likely would have used is different diameters of wire or lengths along the barrel, as the switching period of the coils gets shorter and shorter towards the end of the barrel, meaning you need a lower inductance to peak and dissipate faster.
And maybe the last though i can come up with would be a full cycle push pull as the projectile passes through, as it approaches the opening of the field shell,turn on and begin building up the field, to draw it in faster, it cruises in, then when its approaching the end of the coil you apply a reverse polarity pulse to kick it out while the next coil is drawing it in.
Offline CopperCone
  • *knock knock*
« Reply #20 on: January 18, 2018, 06:00:52 pm »
An interesting note on the darpa mortar is that it uses a 94ghz radar to track the position of the mortar in the barrel. I thought it would be a ldvt.
Do you just put a horn on the bottom of the barrel and measure reflection? Really interesting.
« Last Edit: January 18, 2018, 06:03:23 pm by CopperCone »
Offline ahbushnell
« Reply #21 on: January 19, 2018, 04:48:46 am »
There is a public paper
www.dtic.mil/get-tr-doc/pdf?AD=ADA610358
Offline Richard Head
« Reply #22 on: January 19, 2018, 01:25:18 pm »
I wonder if you could use an energy recovery winding  for every turn on the barrel. This way you may be able to recover the energy that isn't transfered to the projectile.
Offline jbb
« Reply #23 on: January 19, 2018, 08:40:38 pm »
An energy recovery winding might work, but I suspect that copper volume in the coils is critical.  Instead, you could try a two-switch circuit (see below).
To fire, close M1 and M2.  The DC rail is applied to the inductor and current rises.
To hold current, open M2.  Current flows through M1 and D2, 0V applied to inductor, current holds steady.
To release, open M1 and M2. Current flows through D1 and D2, energy is transferred from inductor back to the DC rail.
Offline Vgkid
« Reply #24 on: January 20, 2018, 07:40:38 am »
This is very cool.
