Neat project!
A few suggestions:
Neither your blog nor your post mention the input voltage of your converter. Is it meant to be powered by 12V? Is it meant to be powered from a Li-Ion battery? Who knows ...
How about cooling? These things get hot very quickly, and now your covering the top with your converter. Maybe make the board as narrow as possible, or add a cut-out over the CPU where a heat sink can poke through.
keep going, Werner
