teapo is brand i see crap out a LOT.
QFT. I have a 'dead' EPoX motherboard with about eight Teapo capacitors on it, and about three Panasonics. The Teapos have ALL failed, with bulging tops and/or leaking electrolyte. Maybe that was why the system would randomly restart...?
I have a few other defunct devices with those time-bombs inside.
i wonder how much electronic goods get binned due to a single bad cap or a crappy solder joint??
My dumpster diving, flea market, garage sale, Goodwill, and Salvation Army hunts for electronic goods seem to indicate quite a few things are tossed for very minor reasons. I often find things with broken knobs and buttons, damaged cords, etc., but otherwise they work fine; if it's an item that merely doesn't turn on, I can usually get it for free or at a reduced price. It's too bad people seem to 'need' new things instead of finding a repairman, or better yet learn how to repair it themselves. First-world problems, eh?
In old audio amplifiers, tube and solid-state, I almost always find bad filter capacitors. I hate when I find un-vented caps though, since there's no visually-obvious sign they're bad. A quick check with the ESR meter tells me right away, though. On the bright side, even good electrolytic capacitors are cheap cheap cheap!
IanJ: How old are those boards? If they're from the early 2000s, that's probably a clue as to why they failed:
The capacitor plague (also known as bad capacitors or "bad caps")[1][2] is a problem with a large number of premature failures of aluminum electrolytic capacitors with non-solid or liquid electrolyte of certain brands, especially from some Taiwanese manufacturers.[3] The first flawed capacitors were seen in 1999, but most of the affected capacitors failed in the early to mid 2000s. High failure rates occurred in various electronics equipment, particularly motherboards, video cards, compact fluorescent lamp ballasts, LCD monitors, and power supplies of personal computers. News of the failures (usually after a few years of use) forced many equipment manufacturers to repair the defects. The problem seems to be ongoing; faults were still being reported as of 2010.[4]
Source:
http://en.wikipedia.org/wiki/Capacitor_plague
