Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
LM723 Negative Voltage Regulator - Higher currents, + Current Limiting?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LM723 Negative Voltage Regulator - Higher currents, + Current Limiting? (Read 5342 times)
fivefish
Frequent Contributor
Country:
on:
August 02, 2015, 11:45:02 am »
I'm trying out a 723 negative voltage regulator circuit for 1st time.
The Positive voltage regulator in datasheet shows how to set current limit.
But for their negative voltage regulator (Fig. 18), there is no provision.
How do you set current limit value in a negative regulator schematic?
Logged
SeanB
Super Contributor
Country:
Re: LM723 Negative Voltage Regulator - Higher currents, + Current Limiting?
Reply #1 on:
August 02, 2015, 12:08:33 pm »
Add an external PNP transistor to operate to steal base current, just like the NPN version does. Connected between base of the pass device and emitter, like the positive version, with a sense resistor.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
