Im not sure how many other people moded they uCurrent gold but i thought i would share
i got number 258 ... just 2 off from a perfect number!
FIRST i MUST say that the uCurrent Gold is a GREAT device at a reasonable price and the fact that (the one i got) was hand tested by dave jones him self i cant ask for more than that ... i also got some freebies with it 8D
but i did have some problems ... for one i work with SMPSs without cases and a few other things close to my PC and a laptop and a few other cheep equipment so i live in a fairly noisy environment so when i hooked this to the scope i had some serious problems with quite a bit of noise, i wrapped the case in copper tape, soldered the tape together everywhere i reasonably i could, than put a tab in the case and connected it to the output ground
i ALSO cut some of the traces he used for batch testing ... just because i was in there and had my knife ...
Secondly the coin cell battery is rather useless because of all the space that it has in the case, dave was nice enough to include a 3 AAA battery holder (not sure if he did on all of you ... also some nice gold banana plugs!) so i soldered that battery holder in and glued it down ... the opamp inside can take up to 5v and i went over the circuit hard to make sure nothing was too voltage dependent on the 3v the coin produces ... i decided no and it worked! ... this does not just increase battery life and make them easy to replace but it also gives me a +/- 2.25v fullscale output per range
The binding post was really loose and quickly lost connection ... nothing a good tightening would not fix
Ok this is where i have to be a bit picky .. the amber LED is so damn bright it annoyed the holy hell out of me ... i tried filling it with hotglue and diffusing it with my fingerprints but nothing helped besides taping it over
i thought i would fix this by replacing the resistor going in to the LED with a 1K resistor ... this worked well! ... and no its not close to hitting the input binding post there ... just looks that way, i used to for atleast 3 weeks without problems but after i took this photo (a few minutes ago) i put some heat shrink over it
after all these improvements it worked very well, very well calibrated, very nice gold contacts, LED is now usable, truly usable to full bandwidth, very nice but of kit
Some things that i still dont like:
1: The binding posts are wider than standard ... this does not do any real current handling so i dont mind
2: the switches look really cheap and im curious about there longevity and there contact resistance ... i wont change them out im sure dave did his homework on there but they make be feel a bit uneased
3: i lost a screw, seriously dave you should have anticipated me losing a screw and gone far out of your way to include extras! ... KIDDING ... would have lost the spare also XP ... i had one of the exact type in my junk bin!
Things to come:
I really want to put on a 2000 count voltmeter (will probably make one of my own) and a BNC on a daughterboard for speedy measurements!
[http://i.imgur.com/hOSiNAv.jpg]
[/URL]
