Hello there,
I have looked around and was unable to find data on a diode:
WP90321L75A
so i have no idea what this diode can and can not do. It may be a regular type diode,Schottky, or even a zener.
If data on this exact part number is not found, i might settle for the same base part number data sheet such as:
WP90321L10A
for example. I may be able to extrapolate the spec's from that.
The min specs would suffices i guess if a data sheet is not available, such as type, current, reverse voltage.
Thanks for whatever information you can find.
