Geez man... it took me about 15 minutes to figure out what you had drawn there.
I thought the relays were motor windings at first, until I realized you were trying to draw a relay coil and switches.
two things I see:
1) RLY 2 - the diode is in the wrong place, it should be like RLY 1, across the relay coil.
2) your relay coils are getting current limited by the 220 ohm resistors, which I assumed you put there for the LED's (not the relays). If you're using 5V relays and you're current limiting them on the gnd side, it may not have enough current to pull in the relay. The voltage drop across the 220 ohm is raising one side of the relay above ground by that amount, so the coil voltage is probably too low.
If those are 5V relays, you should instead take the relay straight to ground (and take the LED to ground through the 220 ohm resistor).
