Hello
these are the features and specifications below are photos of some of the measures of an antenna and a filter
Technical Features MetroVna Pro Touch 180 mhz
Coverage 1/180 MHz 160/2mt
Measure R,Z,|X|,SWR,TL,|Phase|,ReturnLoss
Exit DUT -6dBm su 50ohm
Max signal imput –70/+5dB
Accuracy +-2dB
Operating voltage 3.3V
Dimensions 125mm x 95mm x 20mm
Weight 200gr
Functional characteristics
Display TFT 3.1” 16 K coloritouch screen
Ten Menu + four service menu
Internal Rechargeable Battery LI-ion 5000mAh
Battery charging circuit
Interface USB / Bluetooth
updating Firmware USB
compatible with IG/VNA, VNA/J , BluVNA and more
Compatible with Tablet,Smarthphone Android
Platforms SW WIN,LINUX,ANDROID,MAC
IZ7LDG
Antonio
aferrulli@gmail.com
www.metrovna.com
