Hi Gurus!
Attached is a PSU that I am trying to get to work, datasheet for the chip here:
http://www.farnell.com/datasheets/1747276.pdfI have pretty much copied the reference circuit from page 10, just adjusted the FB resistors for ~4V.
This is the second chip that has decided it will stop working for no apparent reason, the first one just died, no output, nothing!
Second one worked for a bit, I had 3.9V on the output, and 0.78V on the feedback, so to be expected, going into the 3.3V regulator, which remains fine, I can feed 5V into the test point and get 3.3V reliably out of the LDO.
The buck decided to adjust it's output to 2.3V to 3.2V randomly, now it is dead, 0V on the output, I have tried changing the inductor, and the caps, tried electrolytic and ceramic, makes no difference.
Current wise, the 3.3V rail has a PIC24 connected to it, which works fine, checked the outputs, the board itself has no shorts, the PSU draws 30mA @ 12V, the 4V eventually will go to a GSM chip, but this is not connected, so the only thing on the buck output is the LDO.
I have designed other switch regs in the past with no issues, these we ~50p on Farnell, should have known better!
Can anyone see anything obviously wrong with the attached circuit, specifically why the chip would fail.
TIA!
