Do you want to convert this to labview because you don't have matlab, or because you need to integrate it with other labview code? If you have matlab available, you can use a 'matlab script ndde' in labview. Then you can just call the existing function without rewriting it.
I tried this but I did not get it working with the mathscript node. I would like to get support here. Preferable I want to program it in LabVIEW with LabVIEW blocks.
The reason I want to make everything in LabVIEW is:
- I have experience with LabVIEW
- I can fully automate all procedures (calibrate and real-time calibrated TDR waveform view)
- I can add it to the software that captures the waveforms from oscilloscope.
I am very close to a working code and it would be a waste to stop at 95%. This normalizing is the "holy grail" for TDR in my opinion
Do you know LabVIEW?
