Hi all,
A client came up with a request that's beyond my experience. basically the product needs a scrollwheel, similar in form and function to that of a PC mouse, but is has to be set in a 1.4mm metal panel. To make matters worse, the wheel needs to be perpendicular to the internal PCB (like an "L" from the user's perspective), although I could connect them with wires if needed. It also has to be off-the-shelf because it's a small production and there's no way to get a custom part.
I looked at rotary encoders but so far couldn't find a kind with a scrollwheel (only thumbwheels), or one that can be mounted to a panel easily the way I need it.
Any ideas? thanks!
