I just designed in the OPAx140 from Texas Instruments. (I'm using the OPA2140, for dual op-amps, but they also have a single and a quad version, IIRC). The specs that I cared about looked good, but without knowing what you're using for it's a little hard to say if it's a good fit. I was worried about relatively low noise, relatively good accuracy, and ridiculously high input impedance with a reasonably low input capacitance. It fits nicely for that application (monitoring audio signal to feed into a DC servo), but it will depend on your application specifics.
