Author Topic: Old Z8671- & P8052-BASIC MCUs  (Read 4910 times)
Offline matsengTopic starter
    • My Github
« on: December 30, 2015, 04:20:25 am »
While rummaging thru my old electronics junk boxes I found both a Zilog Z8671 and an Intel P8052 CPU/MCU. Both are kinda special since they have internal BASIC interpreters and can be programmed by just hooking up a terminal to them.
The Zilog was made in August 1983 and the Intel in December 1984 so they are really ancient.  I also got a bunch of contemporary SRAMS and other crap so I can hopefully get them running without any modern parts. I just need a real VT100 terminal and I'm set :-)
I'll be using one of them for my entry in the Retrochallenge Competition, but not sure which one. http://www.wickensonline.co.uk/retrochallenge-2012sc/
Offline retrolefty
Re: Old Z8671- & P8052-BASIC MCUs
« Reply #1 on: December 30, 2015, 07:04:55 pm »
Cool. That 8052AH may be old but apparently still available for sale:
http://www.micromint.com/products.html?id=97
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #2 on: December 30, 2015, 07:44:08 pm »
Nice find!
I've worked a bit with both. Apparently, you can get a FORTH version of the z8671..
The 8052 has routines for writing basic and assembler programs directly to EPROM, which I found really neat.
Note that when you establish serial to the 8052, the first character needs to be a "space" -it calculates the baudrate from that! I spent a loooot of time on debugging before i knew that...
Looking forward to seeing what you come up with!
--Christoffer
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline TheSteve
  • Living the Dream
« Reply #3 on: October 30, 2016, 01:41:00 am »
Did you happen to ever use the Z8671 and write code for it?
I have an ancient(but cool) battery charger/discharger that uses the Z8671/Z8681/Z8691 CPU's with an external eprom and sram. I'd like to make a few changes to the program and would like to some help with it.
I also have quite a few Z8681 "romless" CPU's in stock if anyone needs one.
VE7FM
