Why not? Or do you think that the arc should take shortest distance between the top and ground?
Yes. Although I suppose it might be possible to insulate the entire unit including power cord but that does not seem to be the case.
Yes we agree sort off. The shortest distance across the coil is definitely not the maximum spark length and that's what you seem to imply. No need for insulating the case or cables. electrostatics do the job for you.
This is a dual resonant solidstate tesla coil , drsstc, they usually perform better then the sparkgapcoils i build. so 18 inches sounds good but 2 feet nah.
In the video it only shows roughly 12 inches though.
A reasonably new disign actually does much better as 1:3. The qcw coil 1:5 or so. But they look alot different and they can't do midi music and so on. just very short bursts. Definitely not this coil.
