Author Topic: Op amp gentle phase fold?  (Read 2105 times)
Offline MTTopic starter
  • Country: aq
« on: October 14, 2017, 11:20:08 pm »
The CA3260 and 3160 have the peculiar feature gentle phase folding while most opamps abruptly phase reverse.
is there any other opamp that does the same as CA3160?
Offline Benta
Re: Op amp gentle phase fold?
« Reply #1 on: October 15, 2017, 08:15:12 am »
Do you mean that the output does not phase reverse when the input goes below the negative rail?
Quite a lot of opamps have this, I've seen several from NSC and TI. It has to be specifically mentioned in the datasheet.
  • Country: aq
« Reply #2 on: October 15, 2017, 06:48:34 pm »
Unipolar supply.
Phase reversal
Phase folding:
Offline Audioguru
« Reply #3 on: October 15, 2017, 09:11:44 pm »
The datasheet for the CA3160 says that it does not reverse the phase when its input goes 7.5V below ground when it has only a positive 15V supply.
Its common mode input voltage range is -0.5V to +12V with a single +15V supply.
Offline Benta
« Reply #4 on: October 15, 2017, 09:17:48 pm »
This is all fine, but I still don't understand what the question is.
Perhaps MT could enlighten us?
Online mikerj
« Reply #5 on: October 16, 2017, 11:13:52 am »
Seems pretty obvious, he is asking if there are any other op-amps that display the same phase characteristics as the CA3260 when the common mode range is exceeded.  I don't know of any myself.
  • Country: aq
« Reply #6 on: October 16, 2017, 01:44:01 pm »
Mikerj nail'ed it! :)  There are some old PNP amps that also folds but does it ugly. Phase folding is a natural transistor phenomenon.
« Last Edit: October 16, 2017, 02:02:51 pm by MT »
