Hi folks, I'm new to the EEVBlog -- someone from Gearslutz suggested I try this forum for my electronics questions.
So I've been tinkering with this reel to real head stack, and as you can see from the picture, you can connect to the heads by using this blue connector port. Unfortunately, if you look closely, you can see that the pins are actually not pins, but rather, little flat metal strips, so standard jumpers won't connect to them. I would love to be able to connect without clipping the wires, but I can't find anything that connects to these flat contacts.
I suspect it would probably be a pipe dream to try to find the female counterpart to this connector port, but perhaps there are breadboard kids that might have jumpers with the female counterpart to the individual contacts? Any ideas?
Thanks!
