Hi
I have a prototype PCB which I want to put inside a metal box for shielding and protection, but it has a few signals on it which I need to probe with a scope from time to time.
I'm looking for a panel mounted test point, which is insulated from the chassis, and to which I can clip a scope probe. (Basically, the same kind of thing that is used to provide the calibration signal on a scope's front panel).
Panel mounted sockets are easy to come by, but protruding pins or loops seem much less common - to the extent that the nearest I can come up with is to use a small socket and actually solder a PCB test point into it. That's ugly, though.
Can anyone please suggest a source for suitable test points? Thanks!
