Hi all,
For a uni project, I need to design an amplifier board that provides at least 35 dB of gain (with the amplifiers I've currently chosen it's 45dB) in the 2.4GHz ISM band.
I've chosen the BGA612 from infineon as my amplifier, and am going to cascade three of them to get my required gain.
However, I'm worried that coupling of the final output will feed back into my first stage and cause oscillations.
What are some good design suggestions/rules/tricks to keep the coupling as low as possible? (Without just making the pcb a lot bigger... Idealy the entire thing would be sub 5 cm long)
I have to use microstrip lines since we are manufacturing inhouse and I can't via stitch for grounded CPW. Every via has to be done by hand (ie, take a bit of wire, stuff it in, solder on both sides, trimm to length).
(I'm going to simulate the entire pcb in Keysight ADS/Momentum, but if I already know what to use to get a good performance, it'll be less tweaking and fiddling around in the end)
