I whole hartedly recomend PRECISE BITS cutting tools in particular theor triple fluted cutters.
Excellent...they have a good selection, good prices, and they are only 2 day ground shipping from me. Thank you for the referral.
If You are interested in RF structures what is the upper limit on frequency of operation?
As high as 20Ghz with some of the high-end substrates is the long term goal. I am hoping to have some freedom to experiment and measure fairly freely to facilitate the considerable learning curve.
Looked at LPKSF and a few other brands and decided to roll my own.
What spindle speeds do you use? The fastest I have is 20,000 rpm and I have always wondered if more speed would have any advantage.
My machine tops out at 15,000 rpm which is pretty quick for regular CNC milling but dead slow for PCB isolation milling. 80k - 100k RPM is a more optimal speed to maximize carbide tools. In my case, I will probably stick with the limitations of 15k as I figure out if the process is worth the effort. If I find myself doing this regularly, I would consider getting a Air Turbine Tools spindle that does 100k RPM. I have other machined parts that would also benefit from that kind of speed.
A lower cost option would be an electric spindle that can do 30k RPM or so but not so sure the effort would be worth the benefit for only a 2x RPM boost.
@IconicPCB - do you use some sort of hood / vacuum to deal with the resulting dust?
