Author Topic: PL2303HX Where to get the real deal  (Read 1269 times)
Offline JesterTopic starter
« on: May 26, 2018, 09:55:10 am »
I need 10, USB to RS-485 dongles for a project. The legit FTDI ones from Digi-Key are a bit steep at $25 a pop.
The clones on Ebay are about $1, but use the cloned Prolific PL-2303HX chip (SSOP28) that causes no end of driver issues with Windows, so one solution might be to simply swap the cloned chip for a real one.
The problem is where to purchase the legit versions, Digi-Key and Mouser don't sell them. Does FTDI or other vendor offer a drop in substitute for the PL-2303HX, if so I can add a dozen on my next Digi-Key order or if they don't, a reliable source for a legitimate PL-2303HX in a SSOP28 package?
Online T3sl4co1l
    • Seven Transistor Labs
Re: PL2303HX Where to get the real deal
« Reply #1 on: May 26, 2018, 10:25:08 am »
I bought mine years ago on Newegg, it might not've even been them but a marketplace seller.  Think it was around $10.
Irony being, because it's old, it's not supported by new drivers; it's as good as counterfeit by the manufacturer.  I forced the original driver version and it's fine.
Ed: RS-232 dongle, that is.
Seven Transistor Labs, LLC
Offline oPossum
« Reply #2 on: May 26, 2018, 10:30:14 am »
Most of the stuff from china has switched to the CH340G. The PL2303 clones are not common anymore.
For example... https://www.ebay.com/itm/132486311868
Avoid these... https://www.ebay.com/itm/321636098509  (RS-485 requires 3 wire to ensure common mode voltages)
Offline viperidae
« Reply #3 on: May 28, 2018, 08:16:23 am »
I would stay away from ftdi and prolific for good. And any other manufacturer that pulls the same kind of stunts with their drivers.
Offline Siwastaja
« Reply #4 on: May 28, 2018, 08:42:00 am »
What would you recommend, then?
Offline Gyro
« Reply #5 on: May 28, 2018, 08:58:40 am »
Go for the CH340 / CH341? At least the 'fakes' are genuine. Check the driver status though.
Best Regards, Chris
Offline Theboel
  • Country: id
« Reply #6 on: May 28, 2018, 10:36:36 am »
Agree
