It depends on the application which AZ OP fits. One parameter is the size of the input stage. This is a balance between bias current and noise. Low noise types generally have higher bias currents. So the ADA4522 is more on the side of very low noise, but high bias. The LTC2057 still has significant bias - about half of the ADA4522. There are also types with much lower Bias but than more noise.
So there is not 1 good AZ OP to fit all needs.
The rather unique feature of the LTC2057 is the high working voltage, especially as LTC2057HV. There are not many alternatives at the high voltage. The AD4822 is one, especially at low source impedance.
The high voltage low noise types have an additional problem: they get relatively warm und thus thermal design gets more important.
