I suspect it is more than this, though. In addition to the observations I have already posted, when doing multiple redundant vias, you do not have to observe minimum clearance rules of really any kind. You can pack them together. I wonder if there's a mathematically best via size and spacing for getting the most copper into a certain area, keeping thickness of plating the same. I mean, I'm sure there is. In a single giant hole, you could put many smaller vias, right? Say you made a single-file ring of small vias just inside the circumference of one giant hole. If the vias were close enough to almost touch each other, that's already more copper, and you haven't even filed in the rest of that hole. And you got all that much more copper plane/pad for heatsinking, where the single hole has nothing but nothing. Question is, how big can you make a via before you are going backwards?
I'm not sure I have ever even seen a lone, super large via, on any product/pcb, before. I suppose it would look like an unpopulated thru hole, but with soldermask over parts of the pad.
