Also, consider using 3 switch topology (2 bidirectional switched in series, with center node connected to ground with a third switch). This greatly increases off-state attenuation.
An alternative is to have a T switch, but instead of ground, feed back a buffered version of the single signal that is switched through. In some situations, particularly for AC, this leads to better 'off' isolation than simply trying to short any stray signal to ground. It effectively bootstraps your second series switch, including its capacitance, to an even higher impedance than it already is. Of course this setup is only acceptable if you can tolerate the possible reverse 'feedthrough' to your inputs via the Cds of the input side switch..
The problem is that in my application, there isn't any 'ground' in many of the applications:
An example: These will be used for wiremapping. This basically means scanning a ohmmeter across a hundred or so pairs of contacts to verify everything is open/shorted as necessary. The 'signal' is coming from the ohmmeter and is largely DC (current source).
The architecture of doing this with a mux is that you have a certain number of 'rows' and 'columns'. In this case, we're talking about a 450 row x 8 column matrix. The ohmeter is connected to two of the rows, and also all of the connector pins on the cables to be mapped are connected to additional rows. You then turn on the fets/relays between each of the two ohmmeter rows and two of the columns. You then turn on additional fets/relays to connect each connector pin 'rows' as needed to measure the resistance. In essence when on you're going through a total of 4 fets each way, which is why low Ron is important in this application.
Another example of my concern is that assuming a 100pf output capacitance on the FET, it seems like just between any two columns (when everythng is off), you'd have 25 pf per row of capacitance (4 fets in series) * 450 rows, or 0.01uF across each pair of rows.
I'm also concerned about passing even modestly 'high' frequency through this array, say even 50khz, for testing for proper connection of a signal transformer. It seems like the capacitance would cause no end of grief.
Oddly, COTS fet matrix products (aka the PXI-2535) seem immune to these effects, so either I'm overthinking this, or I'm not seeing the big picture, or the specs/manuals for the FET matrixes which are available commercially ignore this...
