Hi Florek,
I think you need to provide a bit more info!
Best would be for you to reverse engineer the circuit, as much as possible, showing the parts in question.
Also report on the context on how the power pack is used, if is it powered by battery, or if is it only "driven" by coils under the flywheel.
Possibly you can give the model number of the outboard then people would be able to look up some of this info.
Then I am sure people would be able to comment on the circuit, and on suitable replacement parts.
CDI ignitions are not unknown circuits...
Good luck, Peter
