Author Topic: Pre-twisted Mag Wire  (Read 1605 times)
Offline MattHollandsTopic starter
    • Matt's Projects
« on: September 26, 2017, 05:55:41 pm »
Back in a lab I used to work in, we had reels of pre-twisted mag wire on a spool. This stuff was good for hooking up a scope and basic measurements as the wire was pre-twisted to minimise loop area and it was flexible and didn't need stripping. It was 30 or maybe 32 AWG, one was red and one was green so it was easy to follow.
Now I can't find anything like this one the web and I'm starting to suspect that maybe our lab techs made this in house? Everything with a twisted pair seems to have an outer insulation which makes it stiffer and means it requires stripping etc.
Anyone know where I could buy more of this stuff?
Read about my stuff at: projects.matthollands.com
Offline Monkeh
Re: Pre-twisted Mag Wire
« Reply #1 on: September 26, 2017, 05:59:04 pm »
Buy some cat5e and yank the pairs out?
E: https://www.wires.co.uk/acatalog/tt_wire.html
« Last Edit: September 26, 2017, 06:01:46 pm by Monkeh »
    • Matt's Projects
« Reply #2 on: September 26, 2017, 06:08:48 pm »
Cat5 twisted pairs have plastic insulation whereas I want enamelled. However the "50 Metres 2 STRANDS 0.10mm RED/GREEN Enamelled Copper Wire & Double Silk" looks promising.
Offline Monkeh
« Reply #3 on: September 26, 2017, 06:10:13 pm »
*shrug*, it shrinks right off with the touch of an iron.
Hair thin. The 0.19mm should be closer to what you've used.
Offline langwadt
« Reply #4 on: September 26, 2017, 06:12:02 pm »
plenty of google and ebay hits for "twisted magnet wire"
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: September 26, 2017, 06:19:07 pm »
Bifilar.
Seven Transistor Labs, LLC
Offline Monkeh
« Reply #6 on: September 26, 2017, 06:20:18 pm »
Bifilar.
Isn't bifilar figure 8 shaped?
    • Matt's Projects
« Reply #7 on: September 26, 2017, 06:20:54 pm »
Yep, plenty of google and ebay hits for a lot of things. But all the ebay results for this search are in the US and have high shipping cost and most of the other results that turn up either require getting a quote which is always a pain unless you have a large order.
