I had some luck with getting the IGBTs to go but they seem to be losing around 5 volts from start to finish. I set my power supply to 18v and tried to pass it through the IGBT. I know that I will get some loss, but 5v seems way too much for an IGBT. Should I be using a higher voltage to test a large IGBT like the one I have?
Thanks,
13
