I'm working on a design at the moment using an Artix-7 FPGA. It's not a particularly fast design, but I've been a little surprised at how crappy the square waves look on the scope. What I want to know is; is what I'm seeing normal? is it the best I can expect?
With regards to probing technique, the signal is coming out an 0.1" header pin adjacent to a GND pin. I am using the standard 500Mhz keysight passive probe with the spring ground thingy. (no long crocodile lead or witches hat grabber)
Let me know your thoughts!
Thanks,
Rhys.
