As visible in my last thread in the tools subforum, I recently bought a chinese CNC router.
As mentioned in this here older thread:
https://www.eevblog.com/forum/reviews/china-cnc-6040-setup-testing-review/100/they come with a spindle motor that runs on 230V AC 3-phase (coming out of Variable Frequency Drive inverter),
which is
not mains-earth connected. Did I mention the thing is water* cooled and the O-rings inside are said to fail after some years...
That spindle motor is running on 3 (X,Y,Z) axes (ball screws), so there is quite some movement, bending connected cables back and forth.
While the necessity to fix that is mentioned, details of the proper way to do it are not spelt out anywhere (I've looked).
Now,
it may seem obvious to just use the same type of highly flexible cable that's used for the control lines and lay it out along the same path.
Or one that is even more expensive and has a "guaranteed" higher number of "bending cycles" than the other, so the signal lines are "guaranteed" to break first and when that happens, I also replace the mains earth cable.
The thing is, I don't buy into the "guaranteed", at least not strongly enough to bet my life on it.
Chances are, the earth cable will become suboptimally conductive at the wrong moment and whoever touches this will get a heart attack or whatever.
I don't like this at all.
How is this done properly?
- me
* via a submerged pump in a bucket of water, with 230VAC cable going into the bucket, what a sight! Yeah yeah, double insulation, I still don't like it
Esp. when it says "CE" (china export).
Just for amusement: Currently, my makeshift earthing is outright horrible. The spindle is electrically connected, via screws into hits holder, to the ball screws (which are lubed with a nice insulator I guess), to another part of frame, via another ball screw... to the base frame where I have a screw with a cable attached to it that connects to earth, measuring ~ 4..5 Ohms from spindle case to earth, and who knows what happens if anything actually moves from the current position ;-)
