Is anyone familiar with this type of water meter that has a reed switch mounted above a dial with a magnet perched on top?
With the reed switched removed
(The image gives the optical illusion of a hole through the plastic cover, but it's actually solid on top.)
Are these types of meters easily configured to read a different dial?
Do the red pointers simply pull off, and can I simply rotate the transparent cover so that the reed switch is over a different dial?
