Author Topic: Pulse output from a water meter (mechanical question)  (Read 1392 times)
Offline e100Topic starter
« on: February 12, 2018, 05:38:13 am »
Is anyone familiar with this type of water meter that has a reed switch mounted above a dial with a magnet perched on top?
With the reed switched removed
(The image gives the optical illusion of a hole through the plastic cover, but it's actually solid on top.)
Are these types of meters easily configured to read a different dial?
Do the red pointers simply pull off, and can I simply rotate the transparent cover so that the reed switch is over a different dial?
« Last Edit: February 12, 2018, 05:43:04 am by e100 »
Offline capt bullshot
Re: Pulse output from a water meter (mechanical question)
« Reply #1 on: February 12, 2018, 06:20:18 am »
Don't know about your original quiestion.
What I did with one of these meters: pointing a laser at the fast rotating (black) wheel and detecting the intensity changes to have a real high resolution counter.
« Reply #2 on: February 12, 2018, 06:44:30 am »
Interesting, specs for cheap 1mw lasers quote a lifespan of about 5000 hours or thereabouts, which is only 200 days if operated continuously. Do you get a longer life if you run at a fraction of full power or in pulsed mode?
« Reply #3 on: February 12, 2018, 06:59:35 am »
Yes, the lasers lifespan was a concern - but turned out to be longer than expected. I've used a modded simple laser pointer (remove the battey and pushbutton). The laser output power regulation circuit was so primitive, I could modulate the output just by applying a 170kHz square wave as the power supply (instead the battery). The modulation was used to frequency selective receive the reflected light (ambient light suppression).
This thing worked for 4 to 5 years, then the water meter was replaced and I switched to inductive pickup - as the meter provided for that. I never saw the (el cheapo) laser degrade ...
« Reply #4 on: February 13, 2018, 04:03:49 pm »
Replying to myself, relocating the sensor is possible.
The hardest part was making a tool to unscrew the metal retaining ring that holds the whole thing together.
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
« Reply #5 on: February 13, 2018, 08:21:38 pm »
In the uk I have a similar meter but fitted my own reed switch to it, the lowest order dial has a tiny magnet embedded in it, you can see it in your picture as a silver disk that operates the reed switch. My meter belongs to the water company so I could not possibly disasemble it to swap the pointers and i have to ask why you would want to do that ?
In my case the lowest dial does a revelution every Litre (horrid euro measure) and my software in the house just accumalates those the same as the meter does and displays the same total to a reselution of 1 Litre. Following your sugestion and moving the magnet dial to say 100's would mean my reading reselution would drop to 100 Litres and I cannot figure why I would want to do that  :-//
Offline jack-daniels
« Reply #6 on: February 13, 2018, 09:02:22 pm »
I think the dial the sensor is on is tenths of a gallon and the dial to the left is hundredths of a gallon.
So if he swapped to this one he'd get greater usage accuracy?
EDIT
Looking at it again, I guess the sensor only picks up one full revolution at a time so the dial it's on equates to 1 pulse per gallon where as the one to the left will equal one tenth of a gallon per pulse (or 0.378541 Litre).
« Last Edit: February 13, 2018, 09:57:55 pm by jack-daniels »
Offline fourtytwo42
« Reply #7 on: February 13, 2018, 09:27:32 pm »
So if he swooped to this one he'd get greater usage accuracy?
EDIT
Ahhhh  :phew: now I understand what I missed in the question thank you :)
