24V motor will for sure not withstand 240V, no matter how you pulse it. Do what the others do and take the heater winding and tap it at about 12-15% of the winding to get a low voltage rail to run the motor from. Simple, cheap and you needed the heat anyway. You will need to isolate the whole motor, frame, windings, shaft and fan ( if you are going to use a metal one) to pass mains safety creepage and clearance specs, along with conforming to the EU standard finger test for safety.
If you are looking for pressure you will be stuck with using a centrifugal blower, think of a standard workshop blower, a smaller cousin of the yard blower. A vacuum cleaner motor assembly will do there, they suck at the one end and blow out the other, though you will need a container for it, and a filter on input and output. They are common as universal vacuum cleaner replacement blowers, costs about 30GBP each as spares.
