"Digital Antennas" don't exist, of course, as the RF signal is received no matter what modulation is used. However, the "digital" keyword appears for both commercial and technical reasons: it might hint that a LTE filter is somehow included in the antenna.
Anyway, reading this thread is very frustrating. I do enjoy TV reception as a hobby (and more), including TV, CATV and SAT distribution.
But when someone wants:
- small antenna
- for fringe reception
- in DIY style that should be better than existing commercial products
I can only shake my head...
1) Commercial antennas are designed by clever people for the best cost/benefit ratio.
2) There is the first rule regarding antennas: the bigger, the more gain. Period.
3) DVB-T/T2 requires a good signal, otherwise the receiver cannot produce a propper image, despite error correction. This is actually the main issue with digital terrestrial televisio: it either works or not. While analogue TV allowed to see/hear a noisy broadcast at fringe reception, digital TV will simply fail.
4) DVB-T/T2 is transmitted with less power than analogue TV. Usually they implement SNF (Single Network Frequency), so all transmitters use the same national frequencies for their transponders. This causes ECHOES, if the antenna is not correctly pointed to the best local transmitter. Due to reflections, ECHOES can still interfere with the signal. The use of two antennas might help, where the second antena is connected with a cable with correct length to filter out ECHOES. The DVB-T/T2 standard included ECHOES correction within the GUARD INTERVAL.
5) UHF is preferrably received with line in sight. Those in ground level apartments should mount their antenna on the highest point (roof).
The OP does not provide enough information:
- location
- frequencies
- modulation
- line of sight background
- maximum antenna size
How can he possibly be helped?
Regards,
Vitor
