Author Topic: Quick & Dirty teardowns: Danish Delights - more Brüel & Kjær  (Read 2193 times)
Offline intabitsTopic starter
« on: October 01, 2018, 02:31:40 pm »
A few videos where I have a quick look at the rest of some Brüel & Kjær test gear that I saved from the dumpster over a decade ago.
Type 2760 Power Amplifier
Primarily intended to drive a "shaker" for vibration measurement, but is general purpose and can also drive a speaker.
Type 1902 Distortion Measurement Control Unit
Receives a reference frequency signal from another piece of test gear, and produces two tones of nearby frequencies that can be used to measure several types of distortion.
Type 4416 Response Test Unit
For testing the frequency response of turntable pickups, but can also be used for tape recorders.
Type 4440 Gating System
Allows for the testing of loudspeakers without the need for an anechoic chamber.
Type 6202 Phase Delay Unit
Also for loudspeaker testing. Used with a phase meter, it compensates for the time taken for a signal to travel from the speaker to the testing microphone.
« Last Edit: October 01, 2018, 02:35:00 pm by intabits »
The following users thanked this post: edavid, helius
Offline Conrad Hoffman
    • The Messy Basement
Re: Quick & Dirty teardowns: Danish Delights - more Brüel & Kjær
« Reply #1 on: October 01, 2018, 09:34:35 pm »
I've got a 2706 power amp I use as a test amp on the bench. Really handy little thing. I machined up a custom input plug for it with a barrel and (I think) a banana plug.
« Reply #2 on: October 02, 2018, 08:19:05 am »
I'll try to do something similar. The 2706's would come in handy as you say, and they are probably the only items from this lot that I'll ever use.
