LM2662MX runs upto 5.5v, I have to cater for at least 5.7v (probably safer to assume someone inserts freshly charged NiMh's in the unit which can sit higher than 1.5v). Nice part though.
Ah, yeah, that would be brave...
>Thanks for the offer of a few parts to prototype with, I should be OK - it'll require some serious deadbugging or a PCB to prototype that SOT23-5 properly. Any other 'goto' HF SOT23 boost regulators out there?
Not that I've used - but stick your requirements into LTC's and TI's selection / design forms, and see what spits out. No sane person can keep track of all their offerings!
>Also, is there a 'goto' LDO -V adjustable regulator (negative version of the LM1117)?
Yeah, there's a '3' version, same as there is for most of the rest of the sizes. They're far from low noise, though! (and low noise candidates don't fit on the same footprints). If you can't face buying or building proper low noise regulators, you can clean them up a lot, for not much effort - search for noise eater. Here's a sample.
http://www.techlib.com/electronics/finesse.htmlIt's cheaper and smaller than trying to tame the noise with ever bigger and better capacitors...
TI have a load of low noise LDOs, if you just want to buy something and stick it down.
