I'm working on a project, and am simulating the circuit in Circuit Wizard. I have a setup with transistors activating thyristors (see image).
The LED's are lit by a decade counter. The problem is every now and them (seemingly randomly) when a certain LED lights up, they all flicker. It is not the same LED, and it is not all the time. I do not know if there is a problem with the circuit, or if it is just the program creating this. Also, it is fairly common for LED's to be lit by a transistor with no voltage at the base (again, seemingly random).
The circuit may seem a bit odd in places (e.g. odd transistor placement), but it is not finished and everything there is needed. I de-cluttered it for this image, I replaced most of the circuit for switches (and this did not fix the problem).
The project is the arcade game stacker, but I want to try to make it without using a microcontroller. By this I mean that I want it to work via logic gates and counters within the circuit.
Just for reference, the 555 circuit is just an astable pulse generator, and the other chip is a 4017B decoded decade counter.
Thanks!
