Hi everyone,
just wanted to show a (small) success I had today with a salvaged display from an old (ca. 2010) HP Pro 8600 Premium Inkjet printer.
Apparently it is an A043FW05 - pinouts can be found via google.
This particular display works without any alterations with the Adafruit config files found here:
https://learn.adafruit.com/adafruit-dpi-display-kippah-ttl-tft/installation for their 4.3" setup.
So ... lessons learned:
1) Don't throw away old display's of any sort - chanced are good that they can be reused.
2) Don't be afraid of hand soldering a 45-pin 0.5mm pitch connector - with a normal soldering iron and a microscope it is well doable.
I used mylar-tape to insulate the connector against the pads of the perfboard and to temporarily hold the wires in place. For extra mechanical some epoxy secured the connections more permanently.
Not quite elm-chan level soldering but apparently good enough ...
Currently an external PSU powers the backlight as it requires some 20 mA at 26V minimum for the LEDs. I'll probably also salvage the inverter from the original printer pcb.
Feedback and comments welcome
