Thanks for those datasheets. It is interesting how those water meters work.
Anyway, I just hooked an LED, Resistor, 9v Battery, and a reedswitch from a door alarm together,
and dropped it in the hole next to the counter. And when I started drawing water, the LED was flashing at a rate to match the speed of the flow.
So I guess it really was that easy, and I should have actually done that before posting.
So, very soon I will be able to graph my water consumption (together with Electricity usage that I plan on using the OpenEnergyMonitor type setup.)
So many things to do, so little time.....
