I developed a theory.
Maybe this is how it all started? It seems like you can do it to a TO-220 easily.
Why are you suddenly going off on a tangent about threads and spring force?
I don't know why you don't understand the context but to explain it in clear detail:
1) There is some crap about using too much thermal grease being bad other then non economic
2) there is a claim insufficient mounting pressure is a result
3) there is a claim this is non sense because it should work and mechanically cannot be explained
4) a partial explanation is offered by the mounting geometry of certain packages being susceptible to contamination if excessive thermal grease is used
5) there is a detailed explanation about the functioning of bolts and screws for those that did not read very boring literature about proper screw function (
going off about)
yea im 'going off' maybe try to follow the discussion?
I noticed that people who are not mechanical engineers, and most engineers in general that I spoke to, don't really appreciate the mis behavior of threads from contamination. Plenty of people think "yea its real tight that means its good".
but idk do you say that to your wife when she complains you left your socks on the floor? 'shes going off' ............
