Quick & rough calc:
8A and 0.030 Vds means if you have 100% duty cycle (on all the time) then:
8A * 8A * 0.030 ohms = 2W dissipation in the FET.
How 'small' is your small heatsink...
cheers,
george.
I don't have a datasheet on the heatsink, but it's aluminum and the size of a stamp. I will try to find a bigger heatsink.
I did some rough calculations before building the circuit and got 2.2W of dissipated power (Rds=0.035, 8A). The mosfet's datasheet specifies a dissipation capacity of 62.5C/W, which should correspond to (175-25)/62.5 = 2.4W.
That's probably too close even with a (small) heatsink attached. Perhaps a relay would be a better choice for this? I might even ditch the 555 timer and use a microcontroller with temperature sensing and pid-regulation.
