Yes, the datasheet gives numbers on that.
You may find you'll need an inconvenient number of resistors in series, following the ratings exactly. Pulse ratings (with respect to pulse width) are less often provided, and the parts that provide them are more expensive because they've been tested for that purpose. YMMV.
I normally see 3-4 in series, 1206 size, in an application like that. Mind that commercial mains is only tested to 1.5/2.5kV surge, not 6.
Resistor ratings aside, note that the layout needs adequate clearance. For example, IEC 60950-1 requires total creepage and clearance such that, in event of a single component failure (i.e., one resistor shorting), the remainder is adequate. This is where 3-4 x 1206s comes from.
You may find that it's easier to solve this problem with a few THT resistors, rated for HV or pulse duty. Depends also on what degree of confidence, of standards compliance, and budget, you require.
