I then also noticed that many modern datasheets for metal film resistors specify +/- some ppm as tempco for metal film resistors.
Of course I know that there are metal alloys with different temperature coeffcients of their resistivity - but am I the only one who has been ignorant and always just assumed that metal film resistors would have positive temperature coefficients?
No, it's just you.
But yeah, like they said, check the datasheet.. all sorts of things are available these days.
Oh- brings to mind another classroom experience I had. Inorganic chemistry lab. Band gap. Involves a big Box O' LEDs, cells to light them with, and a dewar of LN2 to chill the lights with.
Chill the LED, record the shift. Plot and write up.
The hypothesis was, well, take this red one here.. chill it and it goes yellow, and green! The blue goes violet then invisible (ultraviolet)! So, clearly, the bandgap is increasing with reduced temperature!
So, being a rebel as always, I grabbed a green (which is GaP, rather than the GaInAsP alloys constituting the red, orange and yellow emitters, or GaN for blue) from the box. Which started green, then got yellow and red under LN2. Response from the instructor? "Uh let's not use that one, it's a bad example..."
I won't say the moral of the story is, some instructors are bad (ignorant?). I would rather say, it is two things:
One, just... research what you're doing, before doing it (ah, I've had more than a few unprepared labs, yes...). So, don't be unprepared, whether for the work itself, or the immediate questions/facts concerning it. Ok, so, "don't be ignorant" kind of IS saying the same thing...
Two, PLEASE, PUUUHHHLEASE don't mislead your students about "X is always this way", when you
damned well sure know it's not anyway! (In your example: that would be generalizing bulk properties of real materials, which are notoriously variable even among the pure metallic elements. Bismuth or gallium's TCE for example.) Just allow that, what you're teaching is an approximation, and that there's always "something more at the bottom" to be found. At worst, you'll have a few bothersome students asking you "why" incessantly (and I would dare say, that's not a bad thing!), at best you'll have inspired a few excellent future scientists.
is it possible for the resistor to change direction of drift due to age/over heating/other factors?
Sure.
I don't have any particular examples or articles to go on, but from what I know of resistance, it should be more than possible, especially if you're rooting around for changes at the ppm level!
- Oxidation of the surface coating (epoxy / enamel /
), leading to decreased resistance, increased humidity sensitivity
- Oxidation of the alloy, reducing resistance, increasing humidity sensitivity
- Diffusion of alloy components; crystallization and segregation; in the element, or in the terminals and junctions as well
- Inhomogeneity due to crystallization, unbalanced thermocouple voltages (also shows up as a voltage error, not purely resistance), corrosion, humidity
- Electrochemical offsets (voltage rather than pure resistance error) due to humidity
The amount of shift in resistance and TCR due to any of these will vary widely by material, design and sealing process, just as the characteristics of different materials differ quite strongly. Recall the basic mechanism at work here: most low-TCR alloys are formulated to have a conspicuous bump in their resistivity, which just so happens to coincide with room temperature (or something near there), either near a peak, valley or inflection point. These parameters are all dependent on tight alloy percentages and uniformity, so to some extent or another, they'll vary even just from crystal shape and such.
Worth keeping in mind, also: even if a resistor is rated for "precision", and up to a 150C or whatever operating limit... that doesn't mean its specs are anywhere near sane at that temperature. Even/especially for low-TC types, this is good reason to keep the temp rise (power dissipation, etc.) as low as possible.
