I currently work in the power supply division of a defense contractor. I am fairly new to power supplies and think doing a project like this would help me at my job.
I have the tendency to want to jump right to the end goal without testing before hand...
It's great that you want to really get into your job like that. You would certainly learn a lot by attempting a supply like this. As it happens, I happened to have some LTSpice files for a similar PSU lying around. The topic is pretty complicated and there are lots of gotchas, so it's probably best to start simple.
As T3sl4co1l points out, a classic hard-switching design will be reasonable with 48V input, and...
Small and conventional will show all the gotchas in SMPS design, and then you can scale up what you've learned.
If I might be so bold, maybe you should try to work your way up the complexity tree. I assume that many of your employer's designs will use microprocessor control and suggest the following 'curriculum':
- Conventional 48V in (hard switched) buck with analog current control chip
- Conventional 48V in buck with microprocessor current control (need current sensing, gate drivers, firmware)
- Conventional 48V in multi-phase buck with microprocessor current control (current sharing, interleaving to reduce ripple current, phase dropping)
- 48V - 12V isolated resonant converter (e.g. active clamp flyback, active clamp forward or LLC)
- Auxiliary resonant buck
As an example of how complicated things can get for a wide range converter, I attached s a screen shot of a modelling attempt. You can see that the circuitry is complex, requiring extra MOSFET, diodes, capacitors, coupling transformer and gate drive. The timing is quite important and there are features like how much delay to impose between the main and auxiliary switch (to allow soft switching to happen, very dependent on load), the minimum on time of the auxiliary switch (got to get the energy out of La), the minimum on time of the main switch (implications for duty cycle) and the fact that at low load currents the dang thing doesn't turn off with soft switching. Oh, and all the timing changes when the DC input Vin changes :-(
Please note that the resonant inductor La is a bit too big and the resonant capacitors are WAY too big in this design, which causes slow switching. Also the turns ratio n should be more like 1.2 to 1.5 to get the energy out of La faster (and thus reduce minimum pulse width). The problem is that once you fix these it becomes necessary to dynamically adjust the delay time between the auxiliary switch firing and the main switch firing (hello microprocessor control).
